Results 1 to 5 of 5
Thread: Dream Come True!
    Mar 2015
    Tyler, Texas
    Dream Come True!
    11034896_10204993039559523_4370627528103923278_n.jpgSo after about 20 years, I am finally the proud owner of a FFR MK4. It arrived on Wednesday and work immediately began. After 2 1/2 days, my son and I have spent about 20 hours working on it. I never realized how long it would take to drill and rivet 1000 times. We have both been very sore but it is well worth it.
    I am using a 1996 Cobra donor along with a base model. I have also purchased some new items just because it is simpler and I feel a little safer with them. There were a few items on back order (like the front springs) but we have managed to move forward without them.
    We have ran into a few little snags here and there, but I have been able to work around them. Still having trouble trying to understand how the accelerator cable connects to the pedal box wall. I am sure there is a connector mixed in with the parts, I just cannot find it. Also had a little trouble with the brake pedal hitting the square tube. Some minor shaving fixed that.
    If you have any ideas about the cable, please let me know. I am sure it is something very simple.
    Hi Paul,
    Congratulations to you and your son. I'm sure he understands that this is a very good investment of time for him (Ha!). My cable is pushed through the outside front foot box and is captured via a groove in the cable flange: held by a "C clip". Mine is a MKIII but I bet they are similar. I just happened to have the inspection plate off. There will be many more little hang ups but it's part of it. BTW, if you don't have an air driven pop riveter you should invest in one. Just makes life a lot easier (ask me how I know).
    Good luck on the rest of your build and enjoy it,
    WEK.
    Senior Member gtaroger's Avatar
    Trenton Mi
    Congrats! Roger
    Mar 2015
    Tyler, Texas
    Seriously considered the air riveter. The 1/8th are not too bad. The bigger ones are a bit tougher. May go get one this week.
    Master Builder
    Long Island, NY
    Harbor freight 39$ cant be beat !!
    Kenny
