Results 1 to 4 of 4
Thread: Courtesy Light
    Jun 2014
    Courtesy Light
    I am almost finished with the wiring on my hot rod. Wow there is alot of wiring, including the A/c, the fan and all the rest. Now I have one last problem. How do I wire in the courtesy light. I know it needs a ground and a always hot wire. But, where do the door switches go. I am thinking back in the hinge area or in the front by the door latch. How has everybody install these lights.
    Thanks, Larry
    Fresno, CA
    Mounted a switch on the hinge side of the door, when the door is closed the lights are off.
    Doug
    Built FFR5196 MKII in 2003, 427w
    Building FFR0058HR, Edlebrock 347-AOD
    Senior Member maczter's Avatar
    Feb 2013
    Xenia, OH
    I am doing a toggle switch.
    FFR HR #530
    Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
    My build blog: http://jacks33hotrod.blogspot.com/
    Member stang_killer's Avatar
    New Haven, IN
    I used the on position of head light switch, you know the dimmer for dash lights rotate all the way and it clicks on.
