Any tips on how to get the ball joint back into the housing? I used Wayne's tip to get the C Clip through the inner race, but the ball joint doesn't "slip" into the rear CV housing. Should I just mallet a little more and muscle it in?
That worked! I forgot I had to remove the balls to remove it. Thanks!
