Fresh off the press.....so fresh I don't even have them posted on my website yet. These Side Scoop Louvers replace the restrictive mesh and open up a much larger area for fresh air to enter the engine bay. Not only that, but they help direct the air toward the engine bay for more effective cooling. Let's face it, there are not a whole lot of options available for getting fresh air into the engine bay to cool it down. The windshield creates a low-pressure area on the entire top surface of the engine bay, so the side scoops are about the only good path for cool air to get in. I have plenty of experience with the GTM to know how to cool down a mid-engine engine bay. It was a significant problem on the GTM, just as it is on the 818. A GTM set up with the FFR provided mesh installed in all of the openings as recommended would create an engine bay so hot that it would burn your fingers on the fiberglass hatch when you attempted to open it. The rear hatch glass would get so hot you could not keep your hand on it after a short drive. l learned how to eliminate these problems on the GTM, and those same solutions will generate the same results on the 818. And getting heat out of the engine bay will naturally create a cooler cockpit so you can enjoy driving instead of feeling like you're driving around in an oven.
I have a significant amount of work in the design of these louvers to get them to fit right, provide additional cooling air and also look good (hopefully you guys will agree?). I'm going to offer an introductory price of $99 per pair. These are shipped as flat aluminum parts that must be assembled and bonded together. They will also come with a cut template to use as a guide to make an accurate cut in the body so the louvers fit properly. You can place your orders by visiting my website and emailing me with your order. Let me know what you guys think.
