So it sounds like cylinders 3 and 4 are not firing. I pull the spark plug wires on both and there is no change in that horrible sound from the exhaust. The sound that I thought was a exhaust leak was the sound of these two cylinders not firing. It looks like I have spark to the plugs. Next I will pull the plugs and see if they have spark. My question is....if there is spark to each of these cylinders....what could the problem be? Running carb, no vacuum.
