Another what goes here thread
There is a hole pictured above the is on the block, right next to the block/trans junction. Right below turbo outlet (stock location). I don't have anything there, which leaves an opening to trans available.
Is there supposed to be something there or just left open as when I purchased the donor?
metros
That is an access hole to the to torque converter bolts on an automatic transmission. I believe I have a rubber plug in there.
Edit: added picture
