My FIA is supposed to look like it was hot-rodded in the late 60's. At least, that's the look I'm going for. I'm using a '68 289 block with an old Weiand manifold and Holley carb. I even used the old distributor (with Pertronix internals). The serpentine belt system just wasn't fitting into the program, and I didn't want to go back to V-belts. My solution was a Gilmer belt system and I'm very pleased with the results. This is just mocked up, so there are missing bolts here and there and the crank pulley is not fully seated.
