0
0
Rear AWIC Mount, Zero Decibel Motorsports
Zero Decibel Motorsports Rear AWIC Mount
http://zerodecibelmotorsports.com/pr...nting-bracket/
What:
A laser cut and TIG welded aluminum bracket, seals, and bolts required to mount a type 14 AWIC core on a FFR 818.
Why:
The type 14 AWIC requires custom mounts as the stock TMIC brackets don't line up with the mounting tabs on the core. The Zero dB rear AWIC mount provides an attractive bolt on solution to mount the core for either standard or clocked turbo arrangements.
Combine this bracket with the heat exchanger brackets ($65), Frozen Boost components (~$500 with Zero dB discount), and the soon to come front AWIC mount (target price: $50) to build a complete AWIC setup for your 818 for less than $800.
TIG welding was performed by a former fabricator for the 2 seater Indy car so you know the welds are good. We might not be going 230mph around the Indianapolis Motor Speedway, but that doesn't mean we don't care about quality.
This is compatible with the AJW center exit exhaust!
Note: The bracket is not reversible for clocked/non-clocked setups. You must order the bracket and specify which application you desire.
Cost:
$125
Shipping
USPS Priority Medium Flat Rate Box, $12.65 (will combine shipping)
Includes
Laser cut, TIG welded bracket
Stainless Mounting Screws
Dowty Seal (bonded washer)
Rubber Washer
Includes extra hardware to plug the unused mounting hole.
How do I order?
Send me a pm, email ([email protected]), or message me on facebook.
Pictures:
Everyone who ordered an AWIC the past week and a half, your brackets are shipping tomorrow. I test fit all of them on a spare trans to make sure they would work. A couple needed the tabs spread out another .050". If you see some marks on the tab from a bolt/nut it's not a used piece, that's from the test fit.
- You may not post replies
- You may not edit your posts
Forum Rules
