Results 1 to 3 of 3
Thread: Cobra Rear Axle with Full Fenders/Tire size and wheel offset
    Mar 2015
    To those of you running the Cobra rear end and full fenders, what size tire and wheel combinations are you running? Offset's? Photo of how your combination is filling up the fender wells would be good.
    Andy
    Nov 2015
    I am looking for the same answer, I hope someone comes up with an answer.
    Muggs
    Nov 2015
    I found some info that may be helpful. You will need 5.5" backspace for the front and a 6-6.5 backspace for the rear depending on the rear end you use. The Moser rear end from FF is 59.25" and needs at least a 6.0" backspace. The 94-98 mustang cobra rear end is 61.125" and would require at least .75" of backspace to fit, do I have been told. I am still looking for that rear end BTW.
    Muggs
