Results 1 to 8 of 8
Thread: Tire and fender issue.
    Senior Member fordboy's Avatar
    I'm getting ready to send my MKIV out for paint...and I noticed that the driverside front wheel looks like it is forward, not centered in the wheel well, and
    on right turns the tire will rub against fender... anyone else run into this, and what did you do ??
    MKIV with standard rack & pinion, Ford Racing 302 Tremec 5 speed.... Basic non donor build. 17" x 9" Halibrands on front with Nitto 555 245 45 17 tires....
    I am not sure about the wheel looking like it is forward. But I do know that the MkIV body has an extra wide lip on the edge of the flare that needs to be removed.
    Huntsville, Al
    is your alignment done?
    i had the alignment done when I got the body on and registered...was thinking about taking it back and asking if there was any adjustment in the a arms that might help.
    Two things:
    First as Erik mentioned, alignment. You'll want a minimum of 3 degrees positive caster along with 1/2 to 3/4 degree negative camber.
    Second, when the wheelwell returns are trimmed and shaped during the bodywork process they'll go from this:
    To this, which will greatly increase tire to body clearance.
    Thanks for the help and like always, Thks Jeff a picure's worth a thousand words.
    Apr 2014
    Yes thanks
    I had the same issue with my MkIV some time ago (see my posts). Both rears and the RH front tires were properly centered in the wheel openings but the LH front was forward.
    I measured the wheelbase and the LH side was almost 3/4" longer that the right side. I contacted FFR about the lower arm being out of spec but was told they checked all the arms in stock and they all appeared normal/the same. The rear end is properly aligned and square with the frame.
    I thought maybe I had made an error when I attached the body but it was pushed up as far forward as possible. The inner edge of the cowl (where it turns under) was hitting the dash panel. Also the rear of the door opening was exactly the same on both sides in terms of location of the door latch.
    The only way I could get clearance was to change out the new 245 front tires with 235's. I also had to tilt the LH spindle back a little more than on the LH side so my alignment is not the same on both sides but the car amazingly steers straight.
    You are fortunately that you found this out before painting. I discovered my when I pulled the car out of the garage for the first time to take some insurance pictures.
    At this point, my only options would be to get an adjustable lower control arms so I could alter the position of the lower ball joint however since the car steers just fine, I have just left it as is.
