Page 10 of 11 FirstFirst ... 891011 LastLast
Results 361 to 400 of 404
Thread: insurance guy 818
  1. #361
    Quote Originally Posted by insurance guy View Post
    I stopped work and immediately did what was recommended by AZPETE. I opened a cold one.
    This guy gives the best advice, right?
  2. #362
    Mar 2015
    Belmar, NJ
    I painted a black edge around the headlight lens cover. I was going to paint the inside of the cover but worried that they would pop off if the paint comes away from the plastic. I now worry that the paint will scratch and look bad. Any thoughts?
    I am happy with the new attachment of the strut hinge. I used rivnut instead as the screws into the fiberglass failed. I continue to thank all the people that share their ideas an help, it makes this build easier and I meet new friends.IMG_1522.JPGIMG_1523.JPGIMG_1524.JPGIMG_1525.JPGIMG_1526.JPGIMG_1527.JPGIMG_1528.JPGIMG_1529.JPG
    818S #343 Delivered 5-20-2015
    First Start 10-17-2015
    First Drive 10-17-2017 ( 100 feet back and forth until I can get off driveway)
    First Drive with a non leaking tuned motor 11-12-2015 (wow)
    Passed NJ State constructed inspection 8/30/2016
  3. #363
    Thought - You did remember to lightly sand the plastic before you painted it, right? If this paint scratches, how would anyone see it if it did not go through to the clear plastic? If it did, why not do a light touch up?
  4. #364
    Mar 2015
    Belmar, NJ
    arghhh
    I guess I will be repainting those soon enough
  5. #365
    BN's Avatar
    Sept-lies Qc.Canada +FL. Danvenport
    Hi did you cut the door where the latch is so it does not hit the striker?
  6. #366
    Mar 2015
    Belmar, NJ
    I don't understand where you mean
    can you send photo
    the kit had a pattern for the latch and I used that.
    I had to trim a little metal as per the instructions , I used a step drill bit and file
  7. #367
    Mar 2015
    Belmar, NJ
    thanks to mikeb75 for the pics, a little cutting and my windows are exactly they way I want them. Only thing I am looking for is a rubber reveal for the other side of the window that would really finish off the edge.
    I am still playing around with drivers door lock.IMG_1530.JPGIMG_1531.JPGIMG_1532.JPG
  8. #368
    Mar 2015
    Belmar, NJ
    I really dislike the way the front hood closes and needs to be stiffer. I will attempt to resolve the issue. I purchased a 5' 1 inch fiberglass angle from Mcmaster Carr. Every 2" I cut a slit on one side. now the angle is able to take a shape. I covered my fender with duct tape and clamped the fiberglass to the edge where the hood lays. What I am trying to do is have the shape of the fenders and fiber glassing that angle to stiffen the hood. After clamping I cut 1" pieces of fiber mat and epoxied to the made slits to hold the shape. After curing I removed the angle and did the other side of the angle. IMG_1536.JPGIMG_1537.JPGIMG_1538.JPGIMG_1539.JPGIMG_1540.JPGIMG_1541.JPGIMG_1542.JPGI am waiting for this to cure.
    More to come
  9. #369
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Cool idea to get the shape of the hood curve off of the fender. I've had hood stiffening on my to-do list for some time and have just never gotten around to it. Let us know how it works out.
  10. #370
    Mar 2015
    Belmar, NJ
    after the angle cured I used epoxy resin and fiberglass to secure it to the hood. I still have to do the other side but I cannot believe how much more rigid the hood has become. Test fitting it on the car. It fits much better as the hood conforms to the fender shape perfectly.
    I will have more pics when other side is completeIMG_1543.JPGIMG_1544.JPGIMG_1545.JPGIMG_1546.JPGIMG_1547.JPGIMG_1549.JPG
  11. #371
    BN's Avatar
    Quote Originally Posted by BN View Post
  12. #372
    Mar 2015
    Belmar, NJ
    used a cylindrical grinder bit on drill. Finished with hand files
  13. #373
    BN's Avatar
    Did you finish your door like me
  14. #374
    Mar 2015
    Belmar, NJ
    same way
  15. #375
    BN's Avatar
    Ok but mine rubs on the strike and I have more than paint stick thick and I file down the screw of the strike
  16. #376
    Mar 2015
    Belmar, NJ
    Now I understand what you are asking.
    I cut the fiberglass door skin until it no longer hit the striker
  17. #377
    BN's Avatar
    Does it still look good?.
  18. #378
    Mar 2015
    Belmar, NJ
    finished attaching the fiberglass angle to the hood. I am quite please with how much more solid the hood feels. It also conforms better to the shape of the fenders. What was looking like a huge amount of cutting to get the hood to sit neat in the space has become a minor sanding job. If your hood is not the way you like consider adding formed stiffners. It was a very easy fix.
    I purchased a new steering wheel and hub that allows me to remove the steering wheel. So much easier to get in and out of the car.
    Used structural adhesive to attach aluminum angle to the inside of the doors. I want an easy way to remove the panels to adjust electric window.
    IMG_1575.JPGIMG_1577.JPGIMG_1578.JPGIMG_1579.JPGIMG_1580.JPGIMG_1581.JPGIMG_1584.JPGIMG_1585.JPGcutting the edge off the door panels was a little tricky but using table saw and going very slow worked out.
  19. #379
    Holy clamps, Batman!! I need to up my clamp-game. Nice work on the hood!
  20. #380
    Mar 2015
    Belmar, NJ
    I built a cedar strip canoe so I have boxes of clamps of all sizes. makes it easy to do most jobs.
    I am having issues aligning my passenger side window. The driver side is almost perfect. Upon closer inspection I see the electric window unit on passenger side is much different than the drives side. There seems to be missing clips that hold the window base. This seems to cause the window to constantly move. Send email to Factory Five for help.
    I need to replace that unit and finish the doors.
  21. #381
    Mar 2015
    Belmar, NJ
    no one sees it with door closed
    I keep the door closed
  22. #382
    Mar 2015
    Belmar, NJ
    I wanted to be able to remove the inner door panels easily to adjust the electric window and I wanted a better edge. Using a table saw I removed the bottom and side edge of the inner door liner. I used acetate adhesive to attach aluminum angles to the door fiberglass as a support for door lines. a rubber edge was put around the door inner liner. I used Velcro to attach the door liner but I think I will drill and tap holes in the aluminum angles to provide a stronger pressured attachment. I am very happy with the result. The door mechanism needs tweaking so the ability to take the liner off allows me to skip the adjustment and actually us the car. One of my electric window units was missing clips to keep the window in place. No wonder I was unable to get the adjustment.IMG_1594.JPGIMG_1595.JPGIMG_1596.JPGIMG_1597.JPGIMG_1598.JPG
  23. #383
    Mar 2015
    Belmar, NJ
    having issues getting the electric windows and door locks to work and look good.
    I found a set of electric door looks and now will change the locks over to electric. Looks like slight modifications but is doable. The manual door locks were just not working right. I hope electric will be better.
    I purchased the Docooler electric controller and will try to install that.
  24. #384
    Mar 2017
    SW Ontario
    Quote Originally Posted by turbomacncheese View Post
    ^^ You can never have too many clamps! I used to hear that on a woodworking show, but it also applies to the garage.
  25. #385
    Harley818's Avatar
    Vancouver BC
    I can see a cedar strip interior coming......
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
  26. #386
    Mar 2015
    Belmar, NJ
    What do you think? I can do the inner door skins and center console.
    Here is Canoe that I built
    https://www.youtube.com/watch?v=quhOjs2rdwc
  27. #387
    Mar 2015
    Houston, Tx
    I think the mystery of the clamp is solved.
    That canoe turned out great!
  28. #388
    Mar 2015
    Belmar, NJ
    converting to electric door locks was real easy and glad I did
    it is so much easier than trying to get that manual key mechanism to work properly
    Took the unfinished car to local car show
    no one had any idea what it was
  29. #389
    Senior Member AZPete's Avatar
    Alan, I'm glad the electric locks gave you no trouble. Be sure to make some sort of manual unlock in case of a dead battery.
  30. #390
    True! Trust him! He's not saying this for nothing!
  31. #391
    Mar 2015
    Belmar, NJ
    can you share a pic or how you set that up? I am interested on how it looks by the wheel well
    thanks
  32. #392
    thanks
    Alan, here's how I ran a cable from the latch unlock lever forward to the left front wheel well for the manual unlock.
    (it's a secret unlock so don't tell anybody. )
  33. #393
    Mar 2015
    Belmar, NJ
    its been a while since my last post. I have really not touched the car. I started doing the body work for paint but is BODY WORK , ugh.
    I have obtained a SMART ELECTRIC and will attempt to do a transplant. Take the entire electrical drive, battery pack, heat, a/c and transplant it into the 818.
    I will have to remove all body panels and have them painted while the transplant is taking place.
    I have no idea what issues I will face , I am not even sure if it will work.
    It will produce plenty of parts.
    I will try to video this entire experience and post it online.
    more to follow
  34. #394
    southern NJ
    Hey insurance guy. I am still interested in the old front end if it is available. I am sorry I haven’t been in contact you know Life and trying to fix the previous owners mistakes have gotten in the way.
    Brett
  35. #395
    Mar 2015
    Belmar, NJ
    I understand
    front end still waiting for you
  36. #396
    Mar 2015
    Belmar, NJ
    The Smart was delivered yesterday
    Cant wait to start deconstructing the both vehicles.
    Anyone needing Motor, transmission and other combustible engine parts let me know.
  37. #397
    Mar 2015
    Belmar, NJ
    I just cannot find the time or enthusiasm anylonger.
    I am looking to sell my 818C
    I will take 12,000 for everything
    I upgraded front end and installed hardtop
    I still have original front and parts for convertible.
    I am in Belmar NJ
    its a steal at this price
    car is registered and licensed and drivable.
  38. #398
    Oh no, Alan! I've been learning some things from you. What happened to the Smart car? Did you do a transplant? Your selling price is certainly a great deal for someone, but I'm sorry you are leaving us.
    Pete
  39. #399
    Mar 2015
    Belmar, NJ
    I wish I knew more about electrical engineering. The smart documentation is minimal and breaking the cam codes is currently beyond my ability. I mounted electric components on bench and continue to try to get it working. I have no room to keep 818 in garage. I started body work, but really find that really dull and painful work. I am busy welding furniture and looking for other projects. I would never drive the car when complete and would rather take the funds and purchase a Tormach 1100 CNC machine.
    I enjoy the builds. I did the same thing with the 2 boats and paddleboard I built. Completed and sold them.
  40. #400
    Jan 2018
    Is the gasoline motor and transmission still in the car and is it still streetable or is some reassembly needed after the electric venture?
