Miller Customs
Page 10 of 10 FirstFirst ... 8910
Results 361 to 367 of 367
Thread: insurance guy 818
  1. #361
    Quote Originally Posted by insurance guy View Post
    I stopped work and immediately did what was recommended by AZPETE. I opened a cold one.
    This guy gives the best advice, right?
  2. #362
    I painted a black edge around the headlight lens cover. I was going to paint the inside of the cover but worried that they would pop off if the paint comes away from the plastic. I now worry that the paint will scratch and look bad. Any thoughts?
    I am happy with the new attachment of the strut hinge. I used rivnut instead as the screws into the fiberglass failed. I continue to thank all the people that share their ideas an help, it makes this build easier and I meet new friends.IMG_1522.JPGIMG_1523.JPGIMG_1524.JPGIMG_1525.JPGIMG_1526.JPGIMG_1527.JPGIMG_1528.JPGIMG_1529.JPG
    818S #343 Delivered 5-20-2015
    First Start 10-17-2015
    First Drive 10-17-2017 ( 100 feet back and forth until I can get off driveway)
    First Drive with a non leaking tuned motor 11-12-2015 (wow)
    Passed NJ State constructed inspection 8/30/2016
  3. #363
    Thought - You did remember to lightly sand the plastic before you painted it, right? If this paint scratches, how would anyone see it if it did not go through to the clear plastic? If it did, why not do a light touch up?
  4. #364
    arghhh
    I guess I will be repainting those soon enough
  5. #365
    Senior Member BN's Avatar
    Sept-lies Qc.Canada
    Hi did you cut the door where the latch is so it does not hit the striker?
  6. #366
    I don't understand where you mean
    can you send photo
    the kit had a pattern for the latch and I used that.
    I had to trim a little metal as per the instructions , I used a step drill bit and file
  7. #367
    thanks to mikeb75 for the pics, a little cutting and my windows are exactly they way I want them. Only thing I am looking for is a rubber reveal for the other side of the window that would really finish off the edge.
    I am still playing around with drivers door lock.IMG_1530.JPGIMG_1531.JPGIMG_1532.JPG
