Thread: Hit a milestone this week
    Dec 2014
    Paris Arkansas
    I had the wife add up all the cost so far and we have hit 40k on a budget build using all major parts from the wrecking yards in the area and a daytrip to Missouri for the IRS 8.8 pig and outer carriers. the engine came out of a 94 F-150 had it bored .030 over and installed all new internals. the car is getting pretty close I put the side pipes on this afternoon. still have wiring and radiator to go I am having a lot of trouble ordering wheels as every one talks about backspacing which I have a ton of, what I want to know about is the offset as the look that I am shooting for is a wheel and tire combo that looks good from the side. Any one out there running 15's could really help me with a offset measurement 15x 9 all around
    17x9s run 6 in BS in the front. Most list the offset as 24mm but I can't measure that so I use BS. 15s should be the same. For the rear I would go wider to 10 inches. Here are FFRs specs.
    http://www.factoryfiveparts.com/15-v...eplica-wheels/
    Dec 2014
    Paris Arkansas
    One of the main reasons I went with this build is because I love the look of the Factory 5 Halibrand replica wheels and not being able to get them has been a real bummer. So I am probably going to go with a set of cheap Cragers and sell the car
    Senior Member fordboy's Avatar
    Still trying to wrap my head around around building an MKIV because you like Halibrands.........
    does anybody know if you can get Halibrands in 4 lug? I'm running factory donor axles.
    Dec 2014
    Paris Arkansas
    Every one can relax I found my HALIBRANDS they are being shipped
