Results 1 to 3 of 3
Thread: Factory rear coils
    Factory rear coils
    The manual is kind of vague in the installation of factory rear suspension. It says to cut "one coil from the top" of the springs. Factory springs have one tight coil at the top before going into coils that are about 1" apart. Does this mean cut off the one tight coil at the very top or do I need to cut more than that?
    I assume you are talking about donor mustang springs right? If so Yes, you need to cut "some" of that tight coil. However I would cut as little as possible. Try threading the spring onto the spring spiral and cut just enough to make that work. It's been a long time since I had those springs but I do remember trying to raise the rear of the car some and found there was only about 1/2 a coil left to support the car. that was w/ the springs that the original owner had cut. I ended up getting another pair. With those I didn't cut anything. I just heated that top coil in about three spots to bend it up so it wasn't closed at the end any more.
    Awesome! Thanks for the advice.
