Administrator
Who wants an 818R built?
I have an 818R that is going to need a home and I have a motor that can make upwards of 450 RWHP. Can be built with this motor or a stock motor, 06 WRX brakes or the huge 6 piston Wilwood calipers, stock 5 speed, 6 speed or a 5 speed with LSD and PPG gearset. I can even do a track delivery with a day of instruction.
760-403-6266
Administrator
I got it out of the trailer tonight and in the shop. The car is very nice, brand new spindles, hubs and bearings, new STI aluminum control arms, VCP trailing arms and track pack lateral links, VCP air to water intercooler, your choice of WRX brakes, Wilwood 6/4 br orakes, or Wilwood 4/4 brakes, Mishimoto radiator, powdercoated aluminum, and the motor is amazing. Cosworth shortblock, GSC stage 2 cams, springs and Ti retainers, ported heads with Manley valves, 1100cc injectors, TGV deletes, Killer Bee oil pan, pickup and windage tray, ACT Prolite flywheel and ACT clutch.
wow, that sounds like FFR should buy it from you and finish a race with it. That thing sounds amazing.
