Mounting my oil cooler and running the lines is one of the last hurrahs before I can fire the engine.
I'm a bit unsure on where to mount it. I'd like to mount it vertically on the passenger side firewall bar just ahead of the trailing arm. However, I'm not sure where the side scoop lines up on the chassis. I have the side louvers and plan on using Craigs side scoops to increase airflow to the area.
Tips from those with mounted bodies? Or those who have mounted elsewhere?
