Results 1 to 6 of 6
Thread: 33 hard top fitment
    Senior Member rcotner's Avatar
    Wilsonville, OR
    33 hard top fitment
    It seems to me that the contour of the hard top at the front pillars does not fit well with the main body. Is that normal? What is to be done to get the hard top to mate with the body in region of the front of the doors. I stuck a sharpie in the space between the bottom of the hard top and the body/door to illustrate the gap.
    Once you bolt it down the gap will get smaller. IMO you have the top too far back in the pic. Maybe my pics will help you out.
    Wilsonville, OR
    Thanks Wallace18! Yes, that helps a lot. With the hard top on does the padded rim over the rear cockpit cover still fit? Where the top sits now is within about an inch of the edge of the back of the cockpit.
    33 Hot Rod #664 BrentM's Avatar
    May 2013
    Quote Originally Posted by rcotner View Post
    No the padded rim is for the roadster. My hardtop is almost flush with the opening in the back of the cockpit. You might want to check the measurement from the dash to the back as there is a specific distance that the manual specifies.
    Wilsonville, OR
    got it. Yep the hard top clearly is meant to be flush with the back of the cockpit. Thanks for the input. Greatly appreciated.
    Aliso Viejo, CA
    Gotta be flush my man. I was able to use a catch latch to mate the two and hold it together so I wouldn't have to drill through the bulk and head and keep it clean. Good luck! Oh yeah, get a wench from Harbor Freight to pull that baby off! So worth it. See my videos if you need a visual.
