Got the wrap and blankets on the ceramic coated exhaust last night. It that doesn't make a difference then nothing will. Also, finished mounting and pluming our electric water pump for the turbo. Blew through it no problem when not running, so water will flow normally when out on track if the pump is on or off, then, when shut down for pit stop, our pit plug will run the pump to keep the turbo cool during pit stops or after running. The pump is on a 180 temp switch, so it will keep pushing water through the turbo until its under 180 degrees.
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
