Thanks Thanks:  5
Likes Likes:  19
Page 1 of 14 12311 ... LastLast
Results 1 to 40 of 529
Thread: Retro Racing R build
    After 100 or so hours of frame prep, we now get to play mechanical. Water neck mod, remake all rear suspension shims for heim joints, changing all mounts to metric (drives one's mechanic crazy when at the track and you have both metric and standard on the car).
    Kirkland, WA
    Why didn't you use a swedge bar for the trailing arm ? Not enough tire clearance ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Hi Retro,
    I like the white chassis.
    Your water pump inlet may stick out to far. By the time you add an elbow, it might rub on the chassis.
    If you decrease the size of your pictures to 1000x750 they will show up on your post.
    I also wanted to go all metric. There are a lot of 1/2" (12.7mm) holes that are difficult or expensive to change.
    Like shock ends and all the rod end holes are 1/2" (12.7mm).
    Aotearoa (New Zealand)
    looks great. I have ordered my 818C and am planning on painting my chassis white so its good to see yours all gleaming.
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
    Clovis, Ca
    That would be my guess. I really like the white.
    Thanks- Chad
    Wait, what's the issue?
    THanks all, white was because our EP cars are white inside and underneath, so you can see each and every leak. The water neck is actually shorter than the pulley, so we are crossing fingers. We installed a double pass rad, with both inlet/outlet on the right side, so that we can plumb down the passenger side of the car. Swedge bar is new lingo to me (rotary noise has killed some brain cells), we just went with what we had, fine tune later, easy change once we know what kind of loads we are dealing with (may go with a small alum. trailing arm with Hiems on each end and some high misalignment spacers).
    Going kind small on the rears, so we will see what happens. Installing a bar on the rear with some lighter springs, looking at some better shocks as well.
    just remember, 1/2" is 13mm......I can live with that
    San Diego Ca 92106
    Now that's funny
    http://gifs.gifbin.com/012010/1264091579_kirk_rofl.gif
    So, it's funny how you can put in 4-8 hours every day and see so little progress, but here we are. Clutch is in (Finally), fuel rails and injectors, header, pan, blah blah. Put the engine in the car, only to find our mounts (racey delerin things) are 1/2" taller than the stock ones, which means cutting our powder coated upper cross member thingy to miss the bypass valve actuator.....
    Thinking about either adding a step down in the center of the car (full length) to cover the header and speed the air down the center of the car and create some down force, or lower the whole floor by 1' (foam covered CF, graphite impregnated). Probably just do the center, less hassle, easier to remove if needed.
    Oh, and still finish the Miata, fix one of the EP cars that hit the wall, put the RX3 back together.........
    May 2013
    Greenbelt, MD
    Why not modify the mounts? Or sell those and buy shorter ones? Lots of companies make them. I also came very close to making my own - they aren't very complicated pieces - but ended up with Group N mounts instead.
    Buzz,
    Thought about it, but we like the clearance of the headers right now, means we only need a 1" step down tunnel. I'm sure it will result in more unforeseen mods, but that just makes it ....fun??
    Harley818's Avatar
    Vancouver BC
    nows the time to drill and tap your coolant line to the degas tank as shown in Wayne's mod. Helps eliminate the air in the coolant system.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    So, we suck at bloging our build, sorry. Wheels, tires, brakes, steering, seat mounts all done, body fit. Starting the wiring, plumbing this week. Looks like Flat black with metallic orange stripes is the winning color pallet....
    Jun 2012
    Beavercreek, Oregon
    If I was KING OF THE WORLD there would be no black race cars allowed. They blend in to much with the black pavement and grey northwest skies . You just can't see them coming up behind you. Red, white, yellow, bright/light blue, whatever but no silver/grey or black. Your project looks great by the way. See you at the track.
    Kirkland, WA
    Quote Originally Posted by Steve Powell View Post
    Gee, Steve you never tell me that !
    Tony Nadalin
    5lb alternator mocked up and ready for install on the car, jacking points installed. Just finishing up the metal on the tub so that we can run water lines, then it's fit the air jacks and start pluming everything. Fuel cell is ordered ($4k...ouch!) and wing is on the way today. Doing a custom wing-thing, will post pictures as soon as the mounts are made and installed.
    Kirkland, WA
    Making great progress ! Looks good.
    Tony Nadalin
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    Nice alternator. One wire or three wire? Powermaster 8162?
    Kirkland, WA
    You just like it because it saves weight !
    Tony Nadalin
    Las Vegas, USA
    Na uh. I like it because, because, ....
    Well I don't have to have a reason! I can just like it if I want to!
    Does it come in an unpainted version?
    Power master, don't remember the model but it is a one wire, 75amp. You have to machine a bushing for the pulley, but easy peasy. Sealed the front of the tub last night, now onto the rear bulkhead. We moved the fuel cell to the passenger compartment, so easy two piece, flat panel. Installing the intercooler tonight....should be fun! Yes, we did go inside/outside with the front panels, easier and better for access to the control arm bolts. (you know the ones.....)
    Senior Member Mulry's Avatar
    Dallas
    Where did you find that water neck mod? I'd like to run our water lines up the middle (since we'll be running a fuel cell on the passenger side) to keep them out of harm's way in a side collision, and that water neck mod would be ideal to get the lines running that direction. Thanks!
    Cut the stock one flush at the mounting flange and weld on a 1.75" or 1.5" pipe (depending on your rad, etc.) You could even weld on an alum. elbow, just in how you want to do it, lots of clearance.
    Dallas
    Excellent. Thanks.
    Floor is in for the middle section, flat bottom for the rest of the car is cut and ready to install soon. Intercooler is almost in, scoop is being cut tonight to fit we hope, should have pics of rad shroud tomorrow as well.
    Dallas
    That is really sweet looking. Couple questions if you'll indulge me:
    Is that an A2A or an AWIC? I don't see any water lines, but they could be obscured by the sheet aluminum. Did you fabricate it yourself or purchase, and if so, where?
    I look forward to seeing the forward scoop and shroud.
    Retro,
    Very interesting intercooler. Will it move with the engine and transmission?
    I suspect that it might hit the rear bumper. I can't tell for sure from that camera angle.
    Air to air, mounted to the top of the transmission so it will move with the engine. Clears the rear facia, oil cooler and transfer cooler will be mounted inside the box!
    Intercooler is a cxracing cooler, heavier than I wanted but good for a start
    Leesburg, VA
    Will your floor be removable? If not, getting the seats mounted could be very difficult.
    We welded in modified seat mounts for the OMP slider and seat, so no issue with the floor. We will be flat bottom for full length with only the center drop down for the tunnel removable under the engine. The center drop will be CF with carbon impregnated in the resin. Center drop down in only 1", but should create some extra downforce.
    Going with the GT250 wing, mounted on blades out of the rear of the car, that are welded to the rear frame. That will both protect the trans, and move the wing back a bit. We are also one-piecing the rear trunk lid and cover, makes it easier to get to the engine.
    will post pics of the front rad shroud once done this week.
    Mar 2014
    Oakley, CA
    That's my plan too, more or less. I won't get to that for quite some time, though. Can't wait to see your solution!
    We did get some stuff done today, seat in, peddle assembly, steering, oil cooler mounted in the inter cooler box, shifter mocked up, radiator outlet box done, etc.
    Pics to follow
    Las Vegas, USA
    I like the intercooler and oil-cooler integrated box. Good idea.
    Dallas
    I just like seeing different solutions to similar problems I love this from a packaging standpoint, but I'd be concerned about the heated air from the A2A providing insufficient cooling for the oil. I'd assume that RetroRacing doesn't share that concern. Care to share why -- is the post-A2A air just not that hot?
    A2A intercoolers are only about 70% efficient, so at 140 degrees out of the turbo, the net intake temp would be about 95, so the resulting through temp would be only 45 degrees above ambient. The cooler you see is a 12x12, capable of about 40k btu, so way over what it would need to be, but we thought better to tape it than to wish we needed more. We plan on mounting the trans cooler to the back of that unit as well. The fitting is for the trans vent, hose and filter later.
    The cooler is WAY more efficient if you control the air, as in force is all through the coolers without spillage. Once we mount the scoop and force fast cool air through the coolers.....
    Bowling Green, KY
    Some interesting idea's. I am going down the same road ducting the radiator exhaust air out through the hood.
    Dallas
    How do you attach the rad ducting at the radiator? That's always been a mystery to me.
    Bowling Green, KY
    Depends on the radiator, on other projects we have made tabs to mount or to attach the duct to or in our case the front radiator support/frame and seal the duct to the radiator with weather striping.
    Dallas
    Depends on the radiator, on other projects we have made taps the mount or attach the duct to in our case the front radiator support/frame and seal the duct to the radiator with weather striping.
    That makes sense. Thanks!
