Results 1 to 8 of 8
Thread: Parts list
    Aotearoa (New Zealand)
    Parts list
    Hey guys,
    I think I am going to buy the parts I need individually locally as I think it could work out pretty cheap. My 818 arrives end of the year so I want to take this time to purchase all the parts I will need.
    Can anyone point me to the parts list needed for the build?
    cheers
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
    Okinawa, Japan
    Your best best is to just buy the PDF manual. That's what I did in preparing for my build and it worked out great, until I bought a C and not a S... Still, a great deal applies.
    FFR Build Status: Reset button hit
    '03 Subaru Impreza eSi RHD...because Japan
    Leesburg, VA
    If you've paid for an 818, FFR will send you a free electronic copy of the manual. This contains a list of all donor parts needed.
    May 2013
    Colombia
    Do you mean you're not using a donor? If so I have a parts list that I can share, not including any engine/cooling/turbo/exhaust parts.
    Other than that, check out Metalmaker's thread for a pictorial of the parts coming out of the donor:
    http://thefactoryfiveforum.com/showt...-you-need-quot
    Other than that, I'd check out the following:
    Aluminum LCA and 2015 STI steering rack from Flatirons tuning
    Cusco tranny and engine mounts
    Wayne's (or verycoolparts.com) rear trailing arms
    Engine cover hinge by Michael Everson
    Hood and trunk latches by Mechie3
    Quote Originally Posted by Speedy G View Post
    Yea no donor.
    Thanks for the suggestions and link.
    Mar 2013
    Here's what I came up with from when I bought my kit. I can't remember if it was off the website or out of the manual:
    Front Suspension Front Lower Control Arms
    Front Spindles
    Front brakes (complete)
    Pads and rotors
    Front Flexible Brake lines
    Front CV joints complete with axle nuts
    CV Boot
    Strut to Spindle mounting hardware
    Steering rack with outer tie rods
    Steering shaft complete
    Steering Column with switchgear
    Steering Wheel
    Rear Suspension Spindles
    Rear Brakes Complete
    Pads and rotors
    Rear Flexible brake lines
    Emergency Brake Cables
    Lower Trailing Arms
    Lower forward Control Arms
    Rear Toe Links
    Rear Outer CV joint
    *Rear Sway bar with chassis mount bushings and brackets
    Complete Engine with Alternator and Air box
    Transmission with Flywheel and Clutch
    Shift Linkage mount to Transmission
    Wheels and Tires
    Starter
    Exhaust Exhaust manifold and Y pipe
    Up-pipe (if turbo)
    Down-pipe with cat (if turbo)
    Oxygen sensors
    Instrument Cluster
    Seats
    Emergency Brake Handle
    Rear seat belts with receptacles
    Interior Door Latches
    Shift Knob and Boot
    Rear View Mirror
    Complete pedal assembly
    Throttle pedal
    Brake Master Cylinder
    Clutch Master Cylinder
    Hazard flasher switch
    E-brake cable mount bracket
    Radiator
    Fans with mounting bracket
    Upper and Lower Radiator hoses
    Fill/Burp Tank
    Overflow Tank
    Complete Vehicle Wiring Harness
    Battery Cables
    Battery
    Brake light Switch
    Fuel System Fuel Pump with Sock
    Fuel vapor canister and lines
    Rear Door Hinges
    Rear Door latches with catch
    Hood Hinges
    Side Mirrors
    Horn
    Charcoal Canister
    Windshield Wiper Assembly
    May 2013
    Colombia
    Here's a pdf with prices as guidance. My take on donor parts is that I'd prefer to use new parts in the suspension, and steering. I had a wheel almost fly off on my used '93 just because the original bolts were fatigued. I really don't want that happening on a sports car in the middle of a turn. The cool thing about not using a donor is that you can pick and choose what to improve. For example, I'm going with Wayne's rear trailing arms as well as the 2015 STI steering rack (13:1). A lot of the other basic stuff you can get from junkyards, etc. I can't upload a pdf so I uploaded 3 pages in jpg format:
    Legend guys cheers
