ReinCarNation
Page 3 of 3 FirstFirst 123
Results 81 to 106 of 106
Thread: LCD Gauges Product Release & Promo!
    Good news about Windows 10 - you can disable the lock screen! That means, the display will not show a Windows background when the tablet comes out of sleep mode.
    It now goes directly to the gauges. I'm still testing over night to make sure, but it seems like it's going to act
    like an OEM LCD gauge! I'll redo the video to show the changes.
    Here's a link for anyone that wants to edit their lock screen on personal computers:
    https://windows.gadgethacks.com/how-...ws-10-0162965/
    Custom LCD Gauges , Data Loggers, Performance Parts
    www.procision-auto.com \\ 647-522-9953 \\ Voice & Text
    I know I haven't said much here about this, but this is such a cool project. I hope many take advantage of what you have created here. I have considered creating something like this for racing purposes, but then, low and behold, the major manufacturers came out with what I had in mind. Granted it costs $5k, but to do the work myself, or hire someone like yourself to do it, well, I would probably end up spending much more.
    I have not seen such OEM type stuff as you are making out there yet, and hopefully you will sell a lot of these.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Thanks Mike, I value your opinions and comments as one of the long standing members on this forum. Aside from your experience with the GTM, you have a vast automotive engineering / racing background.
    This project continues to grow and evolve on a daily basis (literally) and I'm constantly investing resources to make it better.
    Coincidentally, I priced out a set of Autometer gauges earlier this week for a customer. Just the basic four (Speed, Tach, temp, and fuel level) totalled ~ $600 CDN + taxes.
    Hopefully I can turn a few heads with this system and enhance the Supercar status of the GTM/818 (and others) with a more modern solution to analog/mechanical gauges.
    Couple questions...
    Do you have the option of running 2 displays - ie gauge cluster plus console display?
    What are the user input options, ie for navigating menus? I'm assuming touch screen, but that seems awkward in the gauge cluster. Is there a 'joystick' option like in an Audi or other OEM infotainment systems?
    MK3.1 2004 Mach 1 donor.
    GTM #304
    Yes, the "200" model that I have on the backburner uses two processors and two touchscreens. One for the dash and one for the control screen (also can display additional info).
    At the moment the Basic 100 version uses the touch screen.
    The advanced 100 version uses touchscreen, wireless keyboard, and a small toggle stick. It moves in all directions and has a "hat" click function to enter the selection. It's not as pretty at the Audi/BMW controllers, but it
    gets the job done.
    I've also toyed with the idea of using a smaller 2 x 4 " touchscreen as a controller. I have a video of that on YouTube; I'll link it when I get home, but here are some photos in the mean time. I think it would look cool integrated
    just above the shifter.
    Another idea that is a bit further down the road is using an in dash infotainment system to control the LCDi. I've installed one in my car that is Android based with a 7 inch touchscreen. I'm learning to write code and figure out
    methods to interface both units (most likely USB).
    This is very similar to the unit in my car right now:
    The first modules are shipping and it's a humbling feeling. When I purchased the GTM, the thought of creating my own module and LCD gauge system never crossed my mind, let alone developing a product
    to distribute.
    This is the second revision of hardware that integrates an interface board and it's own 5 Volt DC power supply.
    It's more compact, lightweight, and higher efficiency (less power consumption) than my original proto-type.
    As the stages of development pass, the areas for improvements continue to grow. I've found a few setbacks
    with my process that include an ink-jet printer that is just shy of acceptable resolution for printing labels.
    It also does not print on 11" x 17" sized paper. I'll have to find a laser printer that can handle the task,
    or perhaps just have it professionally printed.
    Now that I've discovered the weak links in the build flow, it will make subsequent deliveries much quicker.
    I'd like to thank Brent for taking the leap of faith and being the first to try this product. I'm looking forward
    to his review and constructive comments to help me improve my practices and design.
    Within the next few days I'll be posting the Installation Manual and User Manual for the 100 model.
    The Aventador Skin and Demo software will also be ready fairly soon!
    Contact me if you would like more information or to receive a copy of the Demo software.
    Thank you!
    Tino
  7. #87
    The Aventador skin is now functional and ready for use. Contact me if you would like a Windows based
    demo version to try on your home computer.
    These screen shots illustrate a few configurations that can be had (formatted for 10" LCD screen):
    "Lamp Test" with most indicators shown
    Accelerometer overlay
    Basic display for a less busy looking gauge
    For future options, I'm working on a steering angle sensor that will log data for track analysis.
    This sliding potentiometer can be mechanically linked to the rack to indicate front wheel angle.
    Lastly, I'm very close at configuring the OBDII code. CAN bus is closer than J1850; I'm hoping to
    have both going for early April.
    These are the PID's that I'd like to have working for the first release, along with the ability to
    clear error codes:
    #define ENGINE_COOLANT_TEMP 0x05
    #define FUEL_PRESSURE 0x0A
    #define MANIFOLD_PRES 0x0B
    #define ENGINE_RPM 0x0C
    #define VEHICLE_SPEED 0x0D
    #define IGN_TIMING 0x0E
    #define INTAKE_AIR_TEMP 0x0F
    #define MAF_SENSOR 0x10
    #define THROTTLE_POSN 0X11
    #define O2_VOLTAGE 0x14
    #define ENGINE_RUN_TIME 0x1F
    #define CYCLES_SINCE_CLR 0x30
    #define DISTANCE_SINCE_CLR 0x31
    #define BARO_PRESSURE 0x33
    #define OUTSIDE_AIR_TEMP 0x46
    #define OIL_TEMP 0x5C
    #define INJECTOR_TIMING 0x5D
    #define DEMAND_TORQUE 0x61
  8. #88
    I'm working with another member who would like to order a custom, dual screen setup
    for his car. This would fall under the LCDi-200 order number (as opposed to LCDi-100).
    Here is an example of the main display screen with the console remote touch-screen
    (which can also display data):
    Main dash display with Aventador skin
    Remote screen (minimal clutter)
    "Stats" option selected (example of possible info).
    Note: the electronic engine "START" button changes to "STOP" when the engine is running
  9. #89
    Charlotte, NC
    Dude, that is so cool! And it gives you Soooooo much more functionality than we get with standard gauges.
    Great Job!
    The Stig
    GTM #0081
  10. #90
    Thanks Mike,
    If it already isn't apparent, I'm aiming to have a system that can encompass all OEM system capabilities and then some!
    The project has already exceeded my initial goals, and there is so much more to explore.
    Self-driving GTM? Hmmm?
  11. #91
    After a few emails of customising, the evolution of the remote screen is quite impressive.
    As a promise to our mystery customer, I will not show
    the latest version of this graphic.
    I'm sure he will start a build thread soon and share his setup personally.
    Next on the agenda is finishing off the OBDII code and begin working on the next LCD skin/
    I think it will turn out just as nice as the Aventador skin!
    2014-ferrari-laferrari-instrument-cluster-photo-593454-s-1280x782.jpgc16357c0-7e77-4981-9940-303fc7d47e09-1.jpgferrari-laferrari-zfye-020_1.jpg
  12. #92
    OBDII CAN and J1850 protocols now ready to order!
    This feature has the ability to read codes and display the associated fault.
    You can clear codes as well as scan numerous PID's for engine information.
    The OBDII will be a standard feature on all LCDi kits (excluding basic versions).
    Up to 8 PID's can be logged with J1850 protocol and up to 20 PIDs can be
    logged with the CAN bus protocol.
    Examples of PIDs (if supported by your PCM):
    - Injector Pulse Width
    - 02 Sensor ratio
    - Intake Air Temp
    - Throttle Position
    - Manifold Pressure
    - Barometric Pressure
    - Ignition Timing
    - Engine Temperature
    - Short and Long Term Fuel Trim
    For a more extensive list of OBDII PID's and general info see this link:
    https://en.wikipedia.org/wiki/OBD-II_PIDs
    Note that the Expanded option price has dropped because it results in
    Less wiring and module development on my end. The data can be hardwired to
    the DLC harness, or you may purchased a DLC to DB-9 connector for $25
    that plugs into the vehicles existing port.
    This is an example of the display screen on the LCDi200 system. The OBDII
    data will be displayed on the main screen for the LCDi100 verions.
    Pricing for the LCDi100 kit
    Attachment 67396
  13. #93
    Oct 2014
    Southern Pines, NC
    those future skins look amazing! can't wait to see how this products develops over time!
  14. #94
    I know my bezel could use some professional help, but if you can see past my scratch work, here's a quick
    demo of the boot-up time of the LCD system
  15. #95
    Impressive, much quicker than I would have thought. Is the table in standby mode?
    GTM #304
  16. #96
    Yes, when Ignition is shut off, a relay opens and cuts power to the tablet which allows it to enter sleep mode.
  17. #97
    Pricing update and LCD size change. Now using 10 inch and 9 inch screen sizes. Pricing remains the same for the
    display when going from 8 inch to 9 inch.
    ODBII has two options - hardwired to harness, or dongle (plug into DLC connector).
    AFR added at $50 option for wideband sensor input.
    Thanks for reading!
  18. #98
    We have a game changer here!
    I've been evolving the design of this system to have more OEM functionality, look, and feel. The
    latest update is incorporating an embedded controller and dedicated LCD screen as opposed to
    using generic tablets.
    The new hardware addresses many issues with screen size, boot-up time, connectivity, and lower
    power consumption. It also eliminates the need to charge the tablet batteries, or use a maintenance
    charger when the car is not driven for several days.
    The controller boots up very fast and can handle up to three LCD screens at4K HD resolution. I'm
    not sure that having that much graphic capability will be cost-effective, or necessary but the processing
    power is there to make things smooth.
    Total system weight will be equal, or less.
    Power consumption will be lower as well.
    This system will now be able to compete with 'the big boys' for similar costs that I have been able
    to offer. Once I have figured out the module enclosures and any supporting circuitry I'll start a new
    thread and announce the pricing.
    Forthcoming Changes:
    1.) 9" screen main LCD screen (8.31" wide x 5.0" high)
    2.) 7" x 4" touch screen for remote control and auxiliary display
    3.) Embedded controllers
    There have been many requests for an audio MP3/Radio and backup camera have been made for
    the Remote Screen which I'll be implementing as well.
  19. #99
    Oct 2014
    Southern Pines, NC
    wow, nice work Tino. This is so great for the community! We're lucky to have you.
  20. #100
    I'm losing my mind right now.
    For me, one of the biggest things that made a GTM stand out as a kit car was the interior, and largely the dash. With this advancement to near OEM style electronics, yet customizable for each GTM(or whatever) this takes the entire project up a notch. These days people are attracted to the outside styling of a car, but need to almost immediately get in the car and see what the interior feels like. This project has the potential to bring the interior experience to the next level. If I was building a street car GTM I would be ordering this. No doubt about it.
    www.myraceshop.com
    GTM solution kits
  21. #101
    I swear, Mike hasn't received a dime for his compliments, but maybe I should mail him a big fat cheque?!
    After more testing this weekend, the new screens are ready for the big stage. I just need to find some
    enclosures to contain the controller boards, otherwise everything is directly compatible with the system.
    The only tell-tale giving away the secret that this product isn't a 100% OEM LCD cluster, is that a small
    "HDMI" icon will appear in the upper left corner of the main screen when the vehicle is powered. The icon
    stays on the screen for 3 seconds, then disappears.
    There may be a method to shut off the HDMI indicator, or I can simply disguise it with a "Lamp Test"
    that illuminates all turn signal, high beam, and warning icons when the ignition is turned on.
    The next step is to format the graphics and touch screen areas for the new LCD sizes. An easy, but
    time consuming task! The option for the end user to plug in their own screen still exists; the module
    still communicates over USB 2.0/3.0 on a Window's operating system.
    Stay tuned for a new thread and demo video once the graphics are complete. Thanks for reading!
  22. #102
    Quote Originally Posted by Procision-Auto View Post
    Can't wait for this to be completed!
  23. #103
    Testing is complete and the first couple of kits are rolling out already!
    New options for displays will be: 10.1 inch, 9 inch, and 7 inch
    Some new toys for the system are: Heads-up Display (7 inch), and Audio Player, Huracan skin
    I will start a new thread soon with higher resolution photos and pricing.
    Low Res Samples of the screens
    Low Res Screen Shots (closer to display quality)
    Message me if you'd like to order ahead of the new thread.
    Tino
  24. #104
    Well done Tino on producing an awesome product!
  25. #105
    Senior Member Edgeman's Avatar
    Medicine Hat, Alberta Canada
    How do you make a power window drop (half inch or so) on opening door?
    Tino can this be done with your system? From another post.
    GTM #370
    Car was completed and I have SOLD my car
    http://edgemansgtm.weebly.com/index.html
    Doing what you like is freedom - liking what you do is happiness
    later,
    Doug
  26. #106
    Quote Originally Posted by Edgeman View Post
    Anything is possible.
    In a perfect world, the module would sense when the door handle is
    moved, then send a timed pulse to the electric motor.
    After a preset time, the module would then pop the door open using a
    solenoid.
    On the closing of the door, the module would wait for the 'door close'
    switch to engage, then reverse the window motor. There would
    have to be a limit switch to indicate the upper travel stop… or possibly
    use 'current flow ' to stop the drive signal when the motor is loaded
    (Window at max travel) .
    The trouble with using 'current' is that is stresses
    the window motor which could lead to early failure.
Flat Irons Tuning
