Sun Visor Assemby
Installation Instructions
I. Parts Included in Kit
12042 SUN VISOR, SMOKE, W/MOUNTING HARDWARE, PAIR EA 1.00
12288 SUN VISOR INSTRUCTIONS EA 1.00
13605 SUN VISOR PLASTIC EA 2.00
13606 SUN VISOR BRACKETS EA 1.00
13607 SUNVISOR FASTENERS EA 1.00
II. Tools Required
3/32” Hex key
⅜” Wrench
Flat head screwdriver
Philips screwdriver
Loctite (TM)
III. Installation Instructions
Peel the backing paper off the Sun visors.
Assemble the hinges using the longer screws, washers, lock washers and acorn nuts.
Attach the hinges to the sun visor using the shorter screws along with the flat washers, lock washers and acorn nuts. Use a small amount of Loctite (TM) on these screws because they can work loose over time from positioning of the visors.
Be careful not to get any Loctite (TM) on the plastic, it will form a haze that will not come off.
Be careful not to crack the visors by over tightening the screws.
Mount the four angled clips to the top of the windshield with the tops pointing up and towards the rear of the car using the small countersunk screws.
Slide the sun visors onto the brackets and tighten the pedestals with the 3/32” hex key.
