After five or six or seven (I lost count!!) layers of glass, the flange around the body is done. I had a minor problem with one of the layers, had a bit of unexpected separation between layers. I cut out the separated layer, sanded it down smooth, and laid another two or three layers on top of it. The rest came out fine. I rough trimmed the flange just to clean it up, and here's how it ended up.
With the help of the usual suspects (my kids, their friends) we put the entire body/hood unit on to the frame. (I had to spend an hour and a half cleaning the first six layers of sanding dust. I really have got to remember to cover that thing!!)
It slid on alright, but I could tell that there were some issues that would have to be resolved. The PS just fit, but the alignment "Fangs" are pretty close to the footbox wall.
Getting the hood separated from the body was pretty easy, but not in the way I expected. I had hoped that the resin would not stick to the somewhat waxy back of the blue painters tape and would separate with a little bit of encouragement. Note to self: resin sticks quite well to painters tape. Second note to self: it doesn't stick well at all to aluminum. Not that this information helps me much at all in this situation, but it occurred to me when the aluminum "band aids" popped right off. It turned out that the "camper seal" that I used to create the setback doesn't stick hardly all! I unbolted all the "band aids", unbolted the "Fangs", and with just a bit of pressure, the hood separated cleanly from the "camper seal".
The camper seal pulled right off the blue painters tape (it's not sticky on that side, it's barely sticky on the sticky side!!). The blue tape, however, is stuck securely to the resin flange. I am going to have to do a lot of sanding to get all that tape off the flange. Oh well, live and learn!
