I thought I was doing good when I sourced some aluminum front lower control arms and they had upgraded rear bushings. I'm trying to fit the suspension and it looks like they aren't going to work in their current form.
I don't mind getting them machined, I think the pillow ball design is worth the extra effort. As you see in the pictures, it would bolt up, but the bushings are not flush with the chassis which is just going to put more stress on everything.
I found another build thread that used these mounts, but bolted them up like they were, I'm not comfortable with how they fit.
http://forums.nasioc.com/forums/show....php?t=2553004
