Results 1 to 7 of 7
Thread: Trouble with Headlights, blinkers and running lights
    Mar 2014
    Edwardsville, IL
    I am almost finished with my wiring, but I am running into one big issue. My headlights, running lights and blinkers don't work. I have back up lights and flashers. All the fuses are good. I am hoping someone has run into this problem and there is a quick fix.
    Or if anyone has any recommendations on where to start I would appreciate the help.
    Frankfort, IL
    All are fed through the parking light switch on top of the steering column, which has been known to go bad for no apparent reason. I had to bypass mine and everything worked perfectly.
    Mar 2014
    Edwardsville, IL
    Can you tell me if I need to open or close the circuit to bypass it?
    May 2013
    Greenbelt, MD
    Make sure your hazard light switch is connected first. As I recall, nothing works if the hazard switch isn't in place.
    Mar 2014
    Edwardsville, IL
    Hazard light switch is in and works. I can hear the headlight relay clicking behind the firewall. Just not sending power.
    What the hell is a parking light anyway?
    Senior Member Triathletedave's Avatar
    Calgary
    Quote Originally Posted by jaw777 View Post
    Parking light does not make much sense to me either. Maybe it just provides lighting when you are parked so other drivers can see you.
    I am having the same issue with headlights. I have parking lights, blinkers, clearance, brake, and backup lights, but no headlights at all. The relay clicks when I turn on headlights and high beams, but no power to the bulbs. We have confirmed power to the relay, but not on to any of the bulbs.
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    Mar 2014
    Edwardsville, IL
    My hazard/blinker module buzzes when I turn the lights on. I am assuming something is shorted or wired back in wrong. Unless someone has some insight here.
    I am conceding. My whole wiring harness is coming back out for the want of headlights, tail lights and blinkers. $2200 is starting to look like a bargain.
