Thread: Replicar Deliemma
    Replicar Deliemma
    I'm currently working on a 289 FIA FFR roadster replica. I am working on the form to get it registered in Pennsylvania and found certain things that are driving me nuts. I'm attempting to build a replica of the original with just a few modern touches, mainly for ease of operation. But now I find that I'm required to have bumpers, defroster, wipers (which I am installing) and backup light.
    Since this is a 289 body will the standard MkIV bumpers fit?
    I'm install a small off-road LED light just under the body but I hope above the X-zone required by the state.
    I'm check with the state about the requirement of a defroster on a topless vehicle.
    Has anyone else had these prblems?
    Send a message to my friend "FMJ" (Fred) here. He recently went through the Pennsylvania registration and inspection process and may be able to answer some of your questions. I know that regarding bumpers he maintained that the quick jacks were indeed just that and as far as I'm aware the inspectors agreed.
    May 2013
    Harrisburg, PA
    I just went thru PA title/registration, with my plate/registration arriving 7/22 after 5 weeks of Harrisburg.
    - Yes, bumpers are required for the enhanced inspection and the annual inspection you get after you get the registration. Can you get a ticket if you don't have it on between annual inspection? Sure ... but WOULD that happen?
    - Yes, defrosters are required, as are wipers.
    - Download the Special Construction fact sheet, Subchapter K and Pub 45 from the DMV website. Subchapter E applies to passenger car inspections and special construction vehicles also.
    Thanks for the help but will the standard Mark IV bumpers fit my 289 body?
    May 2013
    Harrisburg, PA
    I am not sure. What is the spacing between the front and rear quickjack holes, both horizontal and vertical?
    Where are you located in PA? There are at least 4 Mk4 in the Lock Haven/Williamsport/Sunbury general area. I am up for a drive if you want to look/compare.
    Husband/father/son mrmustang's Avatar
    Greenville, SC
    Where in PA are you located?
    Bill S.
    Instead of being part of the problem, be part of a successful solution.
    HOW TO BUY A USED COBRA
    I'm in Bristol, PA, NE of Philadelphia.
    Greenville, SC
    Quote Originally Posted by retropt View Post
    Bristol Penn Jersey Auto 215-946-1833 should be able to do the enhanced inspection for you. Give them a call as they are just up the road in Levittown
    Bill S.
    Just up the street from me thanks.
