Results 1 to 16 of 16
Thread: Dual side audi intercoolers?
    Denver, CO
    So I have been going all over the place with what to do about intercooling. I have almost decided I want to stay air to air.
    With that, I am thinking about rotating my intake manifold and running the turbo outlet to a 90 elbow up and do a Y to separate out to both sides. I haven't decided if I can fit the intercooler directly behind the vents or if I should run ducting over the wheel well and use all the space behind the wheel well.
    I am hoping someone comes up with some nice side rear bumper vents like a Porsche turbo. I feel that would extract a lot more air than the opening on the back of the car that nobody has proven air to flow out of yet.
    Do you think two of the audi 2.0t intercoolers would work? Does anyone have a better intercooler to split the turbo outlet to?
    Hard to tell to be honest you may have slight more lag from all the piping. One thing I have not seen yet and might do after I have a running car is simply just add fans to the intercooler and maybe extend the intercooler back a little. Air to water is cool and all but some tracks don't like them and it's more that can go wrong. Some nice spal puller fans I feel will help a lot.
    I would like to move the turbo further back as well some day so I can have a nice intake that's not soaking in heat from the block....
    Suisun City, CA
    Quote Originally Posted by redfogo View Post
    Tried that with an aftermarket intercooler (AMR). Didn't work.
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
    Heat soak to quick ?
    Suisun City, CA
    Definitely. Especially if you're on track:
    Finished: NEVER!
    Clovis, Ca
    Yeah, the rear motor area gets crazy hot. I'm thinking if you utilize the side vents you can possibly have a better outcome. Once I get my motor working correctly, I plan on going from AWIC to A2A.
    Thanks- Chad
    Freeport, ME
    Sorry that I'm so slow but I should have some data soon with my side mount AAIC. I'll spring on some extra thermocouples to get some good data. I think we all need to get creative ducting the air through the front and rear of the body. Between the low open percentage of the FFR mesh, the 1/2 wide aluminum "trim" and virtually no airflow control in the body building the base kit as per the manual is asking for trouble.
    I'm not looking for all out power numbers so my engine won't be stressed much at an expected 240 WHP
    Dan
    Jerome,
    Were your fans blowing up or down?
    I do believe the fans you have are reversible, By flopping the blades and flopping the wires.
    Suisun City, CA
    Jerome,
    Where your fans blowing up or down?
    I tried both. I even went as far as removing the mesh covering that vent.
    Finished: NEVER!
    NH
    Subscribed! Just starting my build so am still considering engine choices.
    Kirkland, WA
    Better yet I have 2 RS6 K04 side intercoolers
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Clovis, Ca
    Those would work. I would just wonder about the turbo lag with the additional piping connecting the two.
    Used Porsche 996 Turbo intercoolers are pretty cheap on Ebay, but I prefer and all aluminum design.
    Thanks- Chad
    Edmonton, Alberta
    I believe high HP 996+ often use upwards of 6" thick intercoolers, and right next to the turbo. There has to be a way to get similar results with side scoops and proper ducting.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    This is an interesting video. At the 55 second point and others there is very little air flow down the side of the car.
    https://youtu.be/N2S5cWCGC5g
    The front of the car acts like a boat pushing a wake out.
    San Diego Ca 92106
    Love that hood and fenders.
    Denver, CO
    There shouldn't be much lag. If you switch a wrx from top mount to front mount, I have not seen significant lag increase. That is similar addition of piping.
