After reading through several threads, I am a bit confused as to the distinction between Daytime running lights and clearance lights. I have an 05 donor, and I cannot find a wiring schematic for any Daytime running lights, but they are referenced in the clearance lights section. Do the Daytime running lights have an independent switch or relay that is not a part of the clearance light system?
BTW, my "clearance" lights work front and back, along with the park lights (separate switch and the hazards and signal lights. I'm just not certain if this means that the Daytime running lights also work.
