I'm looking to run Vision 143 torques 18x9.5 on a MKI in the rear and 18x8.5 in the front will it work? If so what offset and largest tire size can I go with without rubbing interference? It has a stock 8.8 and the Fox body control arms in the front. If this will not work what is the largest wheel tire combo/offset and running the deepest dish rim in the rear.
