Turn signal problems
Confused signal light
Hope someone can help.
Finished up wiring my lights last night. Follows the directions from the forums as for hooking the lights up so I'm very confident they are correct. The problem I'm having is the front turn signal are working opposite the rears which are correct. The running lights are fine as well as the brakes. In addition, the hazards will not work unless the turn signal is either left or right.
I am using both indicator lights and they work correct. I took the hazard switch out and that did not help. Ohmed green wire from switch to left front turn light and that checked good. Going to dig into it again tonight but would really appreciate any advise beforehand.
Tom
