Thread: Extra Close-out Panels?
    LCD Gauges's Avatar
    Toronto, Ontario
    Sorry to start a new thread about this, but I need some visibility to get these
    parts identified ASAP.
    The manual I have stops at page 605 and there is no mention of panels numbered:
    - 25761
    - 25498
    - 25951 [x2]
    - 25682 [x2]
    - 25683 [x2]
    The attached photo illustrates the shapes. If someone can tell me where
    they are supposed to go in the Gen I , I'd really appreciate it.
    Senior Member mikespms's Avatar
    North Miami,FL
    the l shaped piece with 2 holes is a template for the gas pedal mounting holes I don't recall the other piece on the gen2
    - 25761
    - 25498
    - 25951 [x2] closeouts for hood bulkhead
    - 25682 [x2] fins for rear diffuser
    - 25683 [x2] fins for rear diffuser
    LCD Gauges's Avatar
    Toronto, Ontario
    Thanks again!
    The panel with the 5-hole pattern in it is a drill template for the rod shifter linkage thru the adapter plate. If you're running a cable shifter, you don't need it.
    Shane Vacek
    www.vraptorspeedworks.com
    LCD Gauges's Avatar
    Toronto, Ontario
    Awesome, thanks Shane!
    The only pieces I need to attach are the hood cowl area.
