Results 1 to 2 of 2
Thread: factory gages
Hybrid View
    Sep 2015
    factory gages
    I installed the factory gages from my 1995 gt donor and they are not working correctly any suggestions? I followed the instructions using the factory gage pod
    Welcome to the forum. I think you need to be more specific describing your problem in order to get any helpful responses. Also, I'm assuming this is a Roadster? If so, post your question in the Roadster section. More traffic there. Describe your build in more detail, what wiring harness, and exactly what is not working correctly. Has it worked before and stopped working? If so, what changed? Or has it never worked properly? Is the problem intermittent or all the time? Electrical problems can be complex and hard to track down, unfortunately especially with donor wiring if that's what you're using. And not too many guys are using the donor gauges any more.
