I don't know if I'll ever add traction control to my 818, but now that Racelogic doesn't make one any more, does anyone know of a good alternative system?
One or more of the AEM engine management products has it, but that means you have to run it as your engine management system too.
If you want to change everything, you can use a DTA stand alone, it will control all of the engine (and many more around) and with proper wheel sensors you can control traction in many ways. However in order to get a precise control you need a lot of sensors per wheel, which increases the costs. And that is when you already have the DTA ECU...
Tracked May 27/July 26, 2017
Build Completed Winter 2021
i think you can do it with a megasquirt ecu. I believe that comes in waynes kit.
Pretty much every stand alone has it, however I've had very little luck finding feedback from anyone who's set them up.
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
Fast 2.0 has traction control as well.
Never heard of anyone using it though.
I bought the race logic system which is going into my car in the next few weeks. I also have the FAST 2.0 system which I won't use. I guess I will have the option should I want to try it later.
Martin
Previous forum name was "Fezzek"
