I took my MK4 in for its initial alignment. I used the specs from F5 (caster 3 deg, Camber -0.5 deg). The alignment shop's electronic machine does Total Toe in degrees not inches. They adjusted it to -0.17 deg. I took the car out for a test drive and it tracked nice and straight. Does anyone know what 1/16" equates to in degrees? It steered great on the way home.
