Results 1 to 2 of 2
Thread: GTM Custom Wheel Fitment
    Webmaster, FFR
    Middleboro, MA
    Front Size: 8-9.5
    Offset: 50-65 mm
    Backspace Equation (inch): (width/2)+2.5
    Tire Size, 245/45/17. 245/40/18
    Rear Size (275-295): 9-10.5
    Offset: 40 mm
    Tire Sizes: 275/40/18, 285/40/17, 295/35/18, 295/30/19
    Wide Rear Size (305): 11-11.5
    Offset: 46 mm
    Backspace Equation (inch): (width/2)+2.25
    Tire Sizes: 305/30/19
    Extra Wide Rear Size (335)” 12-13
    Offset: 52 mm
    Tire Sizes: 335/35/17, 335/30/18
    Notes:
    1. Wheel width is the advertised width measured at the tire bead
    2. Factory Rear wheels use spacers provided with 275 tires for best fit
    3. Max. recommended tire diameter is 25.9” (from 335/30/18) – fitment of larger sizes is unknown and not recommended.
    GTM Alignment Specifications
    Front:
    Toe In (inches): 1/8
    Camber (deg): -0.25
    Caster (deg): 2.5
    Rear:
    Toe In (inches): 3/16
    Camber (deg): -0.5
    Caster (deg): N/A
    Dave Lindsey
    FFR's Mad Dog
    Good information and specs on tires. I'm wondering if anyone can comment on a few more specifics about tire choices. I'm considering 245/40's on the front & 335/30's on the rear. Any cons to choosing a tire this big? What brands have people liked - Toyo? Kuhmo? BFGoodrich? What grade tire is needed for mostly street/occasional track use? Lastly, when do you use the spacer that came with the kit? Thanks for any info.
