Results 1 to 14 of 14
Thread: Center Caps--Stock Wheels
    Mar 2014
    Silver Spring MD
    I am looking for center caps for my stock Subaru wheels but with out the Subaru logo.
    Any thoughts?
    John G
    Houston
    Quote Originally Posted by john g View Post
    Any thoughts?
    John G
    Just file the raised Subaru stuff off carefully and repaint. Worked for me, used a 6 inch second cut half round file, and it only took a few minutes each.
    Mar 2014
    Silver Spring MD
    Good idea. Thanks.
    Freeport, ME
    I turned new aluminum centers in a lathe with 3 set screws to hold them on. I powder coated them and the wheels and lasered the FFR logo on them
    Mar 2014
    Silver Spring MD
    Update:
    Using Freds idea, I sanded off the Subaru logo and then: (i) attached an FFR logo sticker and (ii) covered the center cap with red vinyl (model airplane covering). I like the idea of the FFR logo, but my execution needs improvement. The model airplane vinyl was easy to apply, but I don't like to look.
    Does FFR offer the logo sticker in a smaller size? I used the 3 inch one available on the website. Smaller ones would be nice for wheel centers and horn buttons. Alternatively, could I have some stickers made in a smaller size?
    Leesburg, VA
    FFR offers black wheels with these center caps:
    http://www.factoryfiveparts.com/fact...8-wheels-gray/
    Maybe they'll sell us just the caps? In fact, I'd be interested in a set as well.
    Encinitas, CA
    Update:
    I have XXR wheels and wanted a FFR logo on the center cap instead. I 3D printed a plug for the hole and printed vinyl logos at vinzdecals.com of the FFR logo in just the size I needed. I used an acrylic casting agent (from an arts supply store) to encapsulate it. The acrylic shrank a bit when curing, so I had to repeat a couple times and then sand/polish for a nice finish. A lot of work just for centercaps, but came out nice, I think.
    Mar 2014
    Silver Spring MD
    I checked with Dan at Factory five. The center caps are not for sale separately.
    Does anyone have a good logo file that I can have printed?
    they have a laminated sticker that goes in the middle of their steering wheel that should work.
    Senior Member AZPete's Avatar
    Or, the Factory Five badges are better.
    Encinitas, CA
    I do... but I got the high-res file from FFR and had to sign a trademark agreement that it was only for personal use, not distribution. I'm sure they'll send you one if you do the same (or just Google 'Factory Five logo' and click on Images ).
    I scaled the graphic I used to 893 pixels across, and had it printed at vinzdecals.com. I've had a number of custom vinyl decals printed from them... very quick and inexpensive:
    http://www.vinzdecals.com/cgi-bin/cu...eatesticker.pl
    I calculated the resolution so that when printed at the max dpi of their printer it was the perfect size for my XXR centercaps. None of the stickers or badges that FFR offers were the exact size I wanted.
    Mar 2014
    Silver Spring MD
    Thanks all for your responses.
    1. Bob. I tried the sticker (see above) but it was too big and the result is a little sloppy.
    2.Pete. Did you use the $15 emblem?
    3. WLeeHendrick. I will try the printed sticker as you suggested. I will look for the casting agent as you recommended. That should make them look professional.
    Yes, John, I used 4 of the $15 badges because . . . well, it seems that on some days I seem to try to spend as much as possible.
    Nov 2015
    I have a set of 3 center caps from 06 wrx limited wheels that I don't need. Thought I'd throw that out there in case you try and modify the ones you have and mess one up.
