Thread: Specifications for Factory Five's GTM Aluminum Performance Wheels
    Webmaster, FFR
    Middleboro, MA
    Technical Specifications of Factory Five's Optional GTM Wheels:
    Front Wheel Size (Diameter x width): 18"x 9"
    Rear Wheel Size (Diameter x width): 18"x 12"
    Front Wheel Backspace: 6.95" (50mm Offset)
    Rear Wheel Backspace: 8.49" (51mm Offset)
    Wheel Lug Pattern: GM style 5 lug x 4.75" bolt circle
    Material: Flow formed
    Aluminum Color: Titanium
    Weight: 18"x 9": 19.5 lb 18"x 12": 22.2 lb
    Front Brake Fitment 13" Z06 Calipers and Rotors
    Rear Brake Fitment: 13.00" Z06 Calipers and Rotors
    Recommended Tire Sizes: Front: 245/40 ZR18 Rear: 335/30 ZR18
    Toyo Proxes RA1 tires are used on our GTM
    Here's a video of Factory Five President Dave Smith discussing the optional GTM Wheels.
    Dave Lindsey
    FFR's Mad Dog
    Senior Member Roger Reid's Avatar
    Caldwell (near Boise) Idaho
    Quote Originally Posted by Mad Dog View Post
    ...Front Brake Fitment 13" Z06 Calipers and Rotors
    Rear Brake Fitment: 13.00" Z06 Calipers and Rotors...
    For clarification will these wheels fit the C6 Z06 brakes as well as the C5 Z06 brakes?
    Webmaster, FFR
    Middleboro, MA
    Yes, the C6 Z06 brakes fit.
    Dave Lindsey
    FFR's Mad Dog
    Member JCHRacer's Avatar
    FFR supplied 1" spacer or no spacer with these wheels?
    Ciao,
    Joel
    Working ever so slowly on GTM #269, Twin Turbo SBC, Ricardo, Kit arrived April 5, 2009
    http://photobucket.com/JCHRacer_GTM_Build
    Senior Member Kempo's Avatar
    Cabo Rojo,PR. USA
    I got the spacers on my kit and the FFR option wheels. Although I need to try them with out the spacers and see if they fit. Mad dog do you know if I can fit them without the spacers? The tire is a bit wider than the rear fender with the spacer.
    Wareham
    Spec'd to fit with no spacers.
    Jim Schenck
    Factory Five Racing
    Cabo Rojo,PR. USA
    Cool I will take them off tonight. Thanks Jim.
    Senior Member The Stig's Avatar
    Charlotte, NC
    Quote Originally Posted by Kempo View Post
    That should give you just enough room for those big meats to fit!
    The Stig
    GTM #0081
