Results 1 to 9 of 9
Thread: What did I do wrong? Check out the tow!
    Dec 2013
    Mi
    Here are some pictures of my power steering rack on the front of my car obviously the toe is way out the inner and outer tie rods are all the way collapsed or screwed in but obviously my toe is out I did everything in the manual I added the spacers to it and cut down the ends of the inner tie rods.
    https://drive.google.com/file/d/0Bxx...ew?usp=sharing
    Need photo...
    Trick Tool Maker, Super Moderator Hankl's Avatar
    Northern CA
    Could it be that you have the wrong tie rod ends? They appear to be too long.
    Hank
    “If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    "The I.E." SoCal
    Quote Originally Posted by Hankl View Post
    Hank
    X2. I don't think I have ever seen outer tie-rods that long. Did they come with the Kit?
    __________________________
    Wrong tie to ends.
    Gorham, ME
    Yep wrong tie rod ends.
    Could also go with a bump steer kit
    Dec 2013
    Mi
    I guess I could possibly be the wrong tie rod ends. The tie rods and the power steering rack came off of a 99 Mustang. I will probably just go with a bump steer kit at this point instead of buying new tie rods.
    Quote Originally Posted by greenn50 View Post
    '99s are wider which helps explain things. I wouldn't just throw a bump steer kit on until you have measured to determine whether you actually HAVE bump steer.
