Does anyone know if the recent CVT's can be reprogrammed ("manual" ratios, "auto" rpm set-point) with something like an Accessport or is it dealer/pro tuner only?
Does it have it's own controller and just read the tach and throttle or does the main ecu control it?
Can it be made to work with an older 2002-2007 donor/engine/ecu?
Also does anyone know the weight/dimensions of the CVT vs the 5mt vs the Auto? Heavier/lighter, bigger/smaller would be better than nothing. I don't really want to pull mine to check while it is still under warranty
