One of these days I’ll get my build log updated, but here’s a more pressing issue. Maybe you have some good ideas in this regard, even… The challenge is – at least for IRS – the axle turns when you attempt to torque the axle hub nut. In your experience what’s the best way to hold everything stationary without breaking other parts, like studs?
My first attempt was with a 2X4 drilled for two studs. At the risk of being laughed off the forum, I’ll report that I actually had limited success with it. The 2X4 tended to split as the torque increased, but I succeeded torqueing both nuts to 190 lbs. (If you look at the photo closely, you’ll notice that the knuckle is on the wrong side, but that's another story…)
Everything is now in its proper place – except that I need to torque my axle hubs again. Maybe there's a better method than lumber - in your experience, what’s the best way to hold things in place?
