Well, the parts are in, I processed them last night, the instructions are done, and I have five Header Tank Kits currently in stock. They can be seen and purchased here:
I'd also like to note that not only did the parts come in for the Header Tank Kits, but www.myraceshop.com also has a couple more Heater Bypass Valve Kits, Power Steering Controllers, Alignment Shim Kits, and 930 Outer CV Axle Conversion Kits in stock.
I also got the makings for the 935 CV joint setup last night, so THAT is under way also. If money is not a concern, but strength to hold over 1000 horsepower...with slicks!...is, then www.myraceshop.com has the driveline parts for you!
