Results 1 to 4 of 4
Thread: Need help..... Again
    Oct 2014
    Southern Pines, NC
    All my pullies are lined up EXCEPT my idler pulley! It's about one rib off?! I need to move it back about 1/4 in. Anyone ever see this? Any fix you guys can think of short of getting the bracket to a fab shop to shorten the spacer?
    Oct 2014
    Southern Pines, NC
    Am I crazy for wanting to just hit this spacer on the bench grinder to shorten it so the pullies line up?
    Senior Member tanderson1's Avatar
    Nov 2012
    Calgary Alberta Canada
    Quote Originally Posted by tucker298 View Post
    I know that i didn't need to cut the spacer.... I have heard that you need to cut the spacer if you use the vspeedworks re-enforcing kit. (I tried to find the link to the vspeedworks kit but his site is down with a database error.)
    Do you have the vspeedworks kit?
    Oct 2014
    Southern Pines, NC
    I'm not sure, I bought the kit partially done from someone else so it could be but I doubt it for some reason, but I did end up just grinding it down with my table grinder. It turned out great and everything lines up as it should..... My impatience took over lol
