0
0
Gtm gen2 window switch
Hi, looking through the manual it seems as if FFR is saying that the window switches will support the amperage for the window motors. It doesn't mention relays at all. Are people using 4 relays for window up and down? Or are you carrying that load across the switch? Thanks. Bob
right through the switch is fine.
Yes....the switches are designed to directly run the window motors....no relays needed.
Shane Vacek
VRaptor SpeedWorks, LLC
www.vraptorspeedworks.com
- You may not post replies
- You may not edit your posts
Forum Rules
