Results 1 to 18 of 18
Thread: Serpintine belt systems
    Mar 2013
    Hi peoples , has anyone used one of these belt systems (tru trac - vintage air or march ) for alt an a/c. Im in aus and havin hard time gettin decent info on fitment clearances.CHEERS
    Norton, MA USA earth
    You can use the stock Coyote Ac in the stock location. No need for additional pulley systems. FFR supplied a bracket for the alternator.
    Vintage airs system will not fit on the Hotrod.
    Just installed a March system on my LS3 powered 33 fits and looks good. Don't know what engine you have
    Mar 2013
    Quote Originally Posted by Carolina Hot Rod View Post
    Cheers Carolina , yeh sorry about engine details. Im in australia using an ls1-6 speed set up . Any chance of a pic , much appreciated.
    Mar 2013
    Thanks Michael for info , cheers
    I used the Billet Specialties system. Their system seems to tuck everything in tight to the block and creating as compact system as possible and looks great.
    Bill Lomenick
    Chotis Bill
    Concept One is worth a look at also
    Mar 2013
    Cheers Guys.
    I'm not sure how to attach pictures, but this is my attempt. The March system does not require you to replace the dampener, but you need to get the adapter for an LS
    Mar 2013
    Cheers Carolina, looks exactly what i was after. cheers.
    Okay, good luck.
    Matt
    Jan 2016
    Looks great, I just got my 33 kit two weeks ago, i am looking for an LS engine and am going with AC, any advice on venders?
    Thanks, Brian
    Carolina Hot Rod.....Can I have the number for the March system that you used?
    I used kwik brackets for ls3. works with all balancer depths with hood and sides, ac and alternator
    Houston, TX
    Kmkm,
    Which Kwik brackets did you use for your LS3?
    I used a March system for alt, a/c, and reverse rotation water pump. I know your not running a Ford, but March makes nice stuff. I'm sure they have the right thing for your application. Murph
    Quote Originally Posted by Murph View Post
    I put the March serpentine system on my 6.1 based Hemi. Well designed product IMO
    Very nice looking kit and well made, but they make no provision for working with an ATI damper. They only design their kits around the stock damper for each engine so I had to have a
    custom spacer made to go between the damper and their second crank pulley because it's a 2 belt system. The 2 belt system also adds extra length at the crank pulley
    so be sure you have that much room to the chassis/rack etc.
    DB 7L Hemi33
    Sorry, haven't looked at the post for a while, mblueye33, the number is 20070, and you also need adapter Hub 358.
    Matt
