Results 1 to 2 of 2
Thread: EZ Fast Wiring Question
    Centerville, Utah
    Anyone have experience with the Ez Fast fuel injection? I am installing mine and unable to understand how to connect the RF harness into the Fast Harness. I assume that I can't just bypass and use the RF harness?
    Senior Member stack's Avatar
    Macedon, NY
    i have done this on my hotrod. I used the coil wire from the RF harness to power the EZ EFI harness. The EZ EFI harness also has direct connections to the battery. When the key is on the coil wire will have 12v and power the EZ EFI computer. The rest of the EZ EFI harness should be stand alone
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
