I'm doing a MkIV with the IRS and 17" Halibrand replica wheels sourced from FFR.
I'm working on seating the replacement wheel studs in the hubs after knocking out the original studs as per the directions.
The directions call for using a washer and lug nut to pull the studs into place on the hubs:
but even using a stack of washers to keep the lug nut closer to the end of the stud I find that I have to use A LOT of force to pull the stud in.
So I have a couple questions:
1. Anyone have clever solutions for holding the hub firm while doing this work? I'm using a bench vise but the only place to grab is the raised area around the stud hole (on the back of the hub face), which isn't square so doesn't provide a solid place for the vise to hold. Holding on the bottom of course allows the hub itself to spin, which isn't helpful.
With this arrangement I find I keep twisting the hub out of the vise as a result of the force I have to apply to pull the stud in. I'm leery of using a vise on the hub itself for fear of crimping it through the clamping force required.
2. Is there anything I should be doing to keep the studs straight? From what I can tell, the best you can do is eyeball them to make them as close to plumb as possible relative to the hub and then count on the pulling force to self-straighten as the seat, but it seems like there must be something I'm missing.
3. Any better options aside from brute force pulling the studs in using the lug nuts?
Thanks as always for your kindness and help.
Paul
