Results 1 to 14 of 14
Thread: 4 cylinder 33 hot rod
    Hello
    I am interested to know if anyone has built a 4 cylinder hot rod? I am interested in power level and transmission choice as well as finished weight.
    Jeremy
    Member 3dGuy's Avatar
    San Jose
    the 4 cylinder ecoboost from ford? or another 4 cylinder
    My build site : www.ScootinThunder33.com
    I am a Honda fan when it comes to 4 cylinders but the eco boost ford might be a little more advanced these days. I am looking for unique package, anything with good hp/cc or hp/# of weight. I suspect transmission options might be a problem.
    Jeremy
    Senior Member 6t8dart's Avatar
    Apr 2015
    Irving, TX
    How about an old OFFY 4 cyl midget engine?
    Milton,DE
    How about the engine/trans from an S2000 ?
    Olli
    San Jose
    I have the 2.3 L ecoboost mustang. So far it's a great engine. Pulls great. It doesn't seem like that particular one is available just the 2.0 from the festa. The 6 ecoboost has much better stats and is what they are using in the Ford gt. As for transmission just make sure u don't powdercoat your frame so it will be easy to modify the mounts to fit.
    Ol Skool
    upstate NY
    You could get the Mopar sprint car engine and put hemi heads on it ....
    Rumbles Rumbles's Avatar
    Charlotte, NC
    I know FFR was working on a EFI harness setup for a Ford EcoBoost in the 818. Once that critical peice of the puzzle is in place for the 818, it should be a simple matter to offer something for the '33.
    Any news on the EFI harness setup for a Ford EcoBoost in the 818?
    Stillwater, NY
    Quote Originally Posted by Rumbles View Post
    Why, you gonna build one? Glad to see you still hanging around Rumbles.
    Is there any talk of FFR doing any other power options?
    Stillwater, NY
    Quote Originally Posted by JRS1977 View Post
    Honesty FFR doesn't "do" anything for the power options other than providing you with engine mounts and exhaust downpipes configured for your engine and a drive shaft matched to one of the listed supported engine/transmission combinations. The rest is up to you anyway so the sky is the limit. For custom install they will delete the components you won't use from the kit.
    Ford Racing put a v-6 Ecoboost in a '33.
    http://www.factoryfive.com/whats-new...-five-hot-rod/
    I guess the video I saw was for mounts for the 4 cyl ecoboost. Thanks
    May 2016
    I saw a video of a mustang with a 4g63 motor out of a Evo. It was with a power glide I think. Those turbo 4 cylinders will easily hold 500 hp with a little build up. I have a few friends that have a lot more than that and shift at 9,000 rpm. Even in a thief Evo that weighs (I'm guessing) 3,000 lbs., they accelerate incredibly fast! There is a company that has a bolt in kit to mate the 4g63 to a th400 transmission. Good luck man. I like different ideas for these hot rods.
    https://secure.buschurracing.com/cat...roducts_id=975
    May 2016
