Group Buy/Interest Check: Rear Grille and LED Lights, Zero Decibel
Moonlight Performance
Count me in for the works.
__________________________________________________ _____________
That man is no fool, who gives what he cannot keep to gain what he cannot lose
I'm definately interested and like the change. However I'm curious how it would look with the license plate moved to the lower mesh area and the top section made with a single hex screen across the full width?
I could make a print out of it or even pay to have a one or two off made up. It's too big for the machine I have access too. I also milled it out (vs laser for production) and it took quite some time. That's one reason for making it a two piece. The other reason was I was going to put the license plate there (though, I have another idea for the exhaust now) and I considered making a third plate. All the parts I sell are made at a third party shop so I try to stock/make things that are mostly universal. If I had two guys that wanted it with the plate in the middle and two guys that want a full piece and two guys that want something else I lose volume pricing.
I'll try and get something tonight or tomorrow.
Mechie3
I'm interested, but I would like to know more about what you are thinking with regard to the exhaust being tied in?
SnyderJD
Same here. I'm planning a centre top exhaust exit and would love it to be incorporated.
Adam _____ Instagram @PopesProjects____
YouTube Channel
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
Would there be more interest in these if they fit the FFR lights?
Mechie3
Hey Craig, I have been thinking that I *might* be interested in exactly that setup....but I'm also interested in not expanding my budget anymore, heh. Would be inerested in seeing what it looks like tho, could you mock up the FFR lights in the existing panels easily?
Here is the full rear grill from Zero Decibel! All I can say is Craig is very cooperative and honest!! The install is no where being complete as the finish work is far away, did not receive a no paint finish! I agree a black finish on a light car will look killer!
Mechie3
Yes, I would probably be in for a mesh sized to the FFR lights with and a lower grille to match.
(macaroni extruders to complement all the cheese grater louvers I got )
Looks good Brian!! I like the side marker lights, I have been looking at every vehicle on the road to find a nice looking one. What are your from?
I can set the lights on top of the panel. It's not a mesh panel, but a mesh pattern cut out of the panel so the rings the lights fit into are integral to the part. They can't be moved on existing parts.
What light positioning do you guys want? Same as FFR? Inverted? Red inside, white outside? Just the red (add your own white led bar somewhere else or mount FFR white somewhere else?
Do you have any white led bars in mind that would work? Personally like the new style lamps they are brighter and more modern than the trailer lamps.
I didn't have any in mind because that wasn't the route I was taking. Just tossing ideas out there.
Yeah I would be interested in seeing the FFR lights just sitting on the top of hte panels, Brake/Turn outside, Reverse inside maybe?
Understand, do you think you could mock something up if I could get you dimensions or a template from harleys bumper with your new lights that you have found in place. FFR are just to RV trailerish for me now.
Yes. Get me dimensions or a template and I'll prototype something.
I would be interested in the complete set up. I never liked the tail lights. This would be a worthwhile improvement for me.
Been busy, haven't gotten back to this yet.
Exhaust: A third plate in the middle. For myself personally, I wanted to waterjet a carbon fiber piece. It would look simliar to the Pagani with the grill on the side and the exhaust having a different surround. Other options would be simple exhaust trim rings (customer provided), a grill that is similar with single round or double round cutouts similar to the light cutouts in the middle of the hex pattern. The only difficult part comes in that there are so many different options getting enough people to want the same one can be tricky.
I did manage to model up the full width grill and and a mock exhaust in solidworks that I can print out or share screen shots of.
Love the mesh rear grille on the new Spyker C8. Reminded me of this thread
I still prefer the split grille with body mounted licence plate. If a separate center grille is offered, that might be the way to satisfy more builders.
Without a car, I have no idea about my options for running exhaust on an N/A engine. I'm hoping to exit somewhere in the bottom cutout, with equal length headers if possible.
I love the plain full grill. I would buy one of those if offered (and then mount the plate in the middle as shown in your second image).
To me it provides a cleaner look by eliminating the extra boarders/transitions and lines of the split grille option, that would otherwise be around the license plate or exhaust, but I do understand the practical/machining considerations.
I'd like an option for the full grill using the FFR lights and a matching trapezoidal grill for the bottom cut out.
I personally like the split grill but Im in the Harley Vman style bumper category. So my opinion doesn't matter quite yet. I was wondering if you were able to draw something up with his dimensions yet so I could test fit the print out. I would love a matching bottom cutout and I could get you dimensions on that since I just got the bumper and prepping it for install.
I just made a cad model.last night for Harleys bumper.
Where you able to get 2 large ones in or one small and large combo?
A third vote for the matching lower grille. If voting favored the full upper grille, it might look better if the top was arched to follow the body line, like the Spyker C8.
It will be difficult to change my mind for the split grille and body mounted plate though. Stubborn Italians!
Well, it took me long enough. Paper test fit of the lower trapezoidal grill. Going to have this quoted soon. Also posted a pic of similar grille styles that I made for the Harley style rear bumper. Once they're all quoted I'll probably start a new thread with all of the available types with pricing. All of the grills are mounted using flush pem studs and have the same hex pattern.
Powder coat those grills and its one of the nicest rear ends I've seen!
Hey Mechie! I love the idea of a grill for the lower area - the hex pattern looks great! I'm using the diffuser and was just planning to leave that space open (it was just too plain without a cutout or SOMETHING), but I like your grill, so thanks. I look forward to seeing the final product/design.
I'm in for the lower trapezoid (Factory Five Bumper) and rectangle specs we discussed via email previously. Let me know when you're ready to put the order in and what I owe you.
Hi Craig, Im in for the
trapezoidal lower grille.
And the LED rear led lamps
With PEMS on both
Thanks Don!
Craig, I'd like to do the diagonal upper setup with staggered light sizes, what's the projected cost on those for reference?
