Results 1 to 24 of 24
Thread: SCCA/NASA legal 818
    SCCA/NASA legal 818
    Hi
    I would like to know how many cars currently have log books and can race. Any pictures or opinions would be greatly appreciated.
    Jeremy
    Feb 2014
    Asheville, NC
    Chad's car was raced in NASA ST2 before he sold it. Pics on this thread (here)
    Bowling Green, KY
    My R it targeted to be on track in April, I am pretty sure I will miss the March NASA event here. The car is getting really close but work is starting to eat up my car time.
    Brandon Pantas started racing his 818R in ST3 toward the end of last season.
    Feb 2014
    Asheville, NC
    Mine's been on track and I have a membership to a local track (NYST) this year. I don't have plans for NASA events until later this year. I want dial in the car and the nut behind the wheel a bit more first.
    I totally have the save problem with the loose nut behind the wheel. So I take it that there is no caged hard top racing yet?
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Quote Originally Posted by JRS1977 View Post
    Not yet
    Kirkland, WA
    There is at least 1 center drive 818 on the track here in the NW that is running SCCA, ICSSC and NASA, there are 2 more (mine and Retro Racing) that will be on the track soon also here in the NW, so I expect to see 4-5 818R on the track here in the NW this race season.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Damn straight!
    I have submitted the 818R for classification to SCCA, and have been told it can race in Regional class SP, but not in any "National/Majors" classes, as it is not a production based car.
    Bowling Green, KY
    I would think a case could be made for a SCCA production class, they allow the Caterham which is a kit. Now to make it happen would be quite the challenge.
    I did actually bring it up to Lisa Noble and Board member Steve Harris, was told it would have to go through the comp board.
    Feb 2013
    Westminster, MD
    Here's a shot of my 818R from a local AX.
    Nice picture, I like the way your tire tracks are smoking.
    Are you drifting out of a corner?
    Nov 2012
    The Caterham is a direct descendent of the original Lotus 7, which was considered a production car back when the standards weren't too high. So it is kind of the ideal case for a kit car, plus I think it's being allowed has always been controversial and unpopular with some.
    But if FFR could build 1000+ 818's with the same configuration, they would have a shot. Regional Special Production is actually not a bad option, you could even claim you were a National champion if you won at the ARRC.
    NASA ST is probably a better bet, but again you sort of need more cars to get exempted from some of the non-production penalties.
    Kirkland, WA
    Quote Originally Posted by Grintch View Post
    There are quite a few Caterham's here in the NW, they are allowed to run Vintage also, they are a good run for the challenge car. So we have them running in SCCA vintage, SOVREN and ICSCC. My 818R now has a SCCA and ICSCC log book.
    Tony Nadalin
    Senior Member Rob T's Avatar
    Woodruff, SC
    I have the original application that Chad used for ST2. If you'd like a copy, let me know and I can send it to you. I don't plan on racing yet. I am working at becoming a better driver and learning the car.
    Feb 2014
    Asheville, NC
    I'd like a copy of that! Can you host it on Google docs or something and post a link for all of us?
    Frank - Build thread
    Bowling Green, KY
    https://nasa-assets.s3.amazonaws.com...2--4-20-16.pdf
    https://nasa-assets.s3.amazonaws.com...cial_Rules.pdf
    https://nasa-assets.s3.amazonaws.com...m--12-5-15.pdf
    A few links that you will find helpful, on the NASA site is also a ST calculator which is really easy to use.
    Kirkland, WA
    Hi
    Jeremy
    I have 2 log books for my 818R, SCCA and ICSCC
    Tony Nadalin
    Bowling Green, KY
    Your car looks great Tony.
    Jan 2015
    I have log books for ICSCC in Washington where it can run in SPM, and a NASA logbook for ST-3
    Quote Originally Posted by Leodelc View Post
    WOW, Nice center seat, big wing, side scoops, center hump with scoop, Team Dynamic Wheels and molded in door vents.
    What other good stuff did you do? did I miss you build thread somewhere?
    Jan 2015
    I had to focus my time building, so I did not post a build thread. I built this car to run the 25 hours of Thunderhill. This year will be our first showing.
    Some design details:
    Center scoop is functional, it forces air through the intercooler. Dropped my manifold temp rise in half.
    Front and rear anti-roll bars
    Solid rear suspension joints
    Coolant tubes run entirely within the cockpit for protection
    Dual-master cylinder 600-series Tilton pedals and Wilwood brakes
    Butler seat and raked seating position provides ample helmet/roll bar clearance even for my 6'2" co-driver
    Dry sump oiling
    LED headlights and apex lights for night racing
    Illuminated (EL) side number plates
    Titan steering rack
    Motec dash
    Steering angle, brake pressure, wheel speed, and shock displacement instrumented
    K-tuned shifter
    Administrator
    Enterprise Alabama
    Could you post more pic of the green car?
    Dayum. Love the green. How does it drive?
