Results 1 to 1 of 1
Thread: Beautiful FFR roadster - SOLD
    St. Augustine, FL area
    SOLD!
    Factory five Cobra with IRS option. Non Donor build
    Car has approx 9500 miles, always garaged
    Cost to build - approx $45,000 (Have spreadsheet with details)
    Selling price - $40,000, Price drop to $36,000
    New Engine,Transmission & clutch 01/25/2016) Spec sheet available
    393 cu short block (450hp)- steel crank, forged steel rods & pistons ARP fasteners
    Balanced & blueprinted (28oz) build sheets included
    New Ford Racing Z304 aluminum heads M-6049-Z304DA with ARP studs
    T&D shaft rocker arm system
    Wiend 'Stealth' manifold
    Lokar Throttle bracket kit
    New Holley 750cfm "double pumper" carburetor
    Custom tune by Oakes Racing - 450hp+
    Big Block Cobra 427 aluminum valve covers
    Crane "Fireball" Electronic ignition with rev limiter
    New MSD Pro-Billet distributor
    New Ceramic coated tubuler headers
    Polished Stainless Side Pipes
    Accessories drive kit -Aluminum bracket & pulleys front engine
    LevyRacing Super Alloy T5 Gear Box
    Steeda Triax Shifter, Trans Mount & Bushing`
    Steeda Adjustible Clutch Cable, Quadrant & Firewall Kit
    Broward Powertrain custom driveshaft with safety loop
    8.8 IRS differential
    Perma Cool fuel/water seperator bracket & filter
    Polished Aluminum Catch Can (1 quart)
    aluminum high flow radiator
    Complete Mustang Cobra Brake Kit (new) - Front (dual piston) & Rear
    Carbotech High Performance Brake Pads
    Staniless Steel Brake Lines throughout
    CNC dual brake master cylinder, with cockpit brake bias adjuster
    Adjustible Vintage sway bars front & rear
    Tubular Front upper & Lower control arms
    Coil over shocks
    Cockpit:
    'Rolled' cockpit edges
    Quick detachable steering wheel hub (good security feature)
    Choice of leather covered or traditional wood steering wheel
    Windwings kit
    Custom leather dash with glove box
    Left & Right Leather door panels
    Leather covered console
    adjustible footwell vents
    WSH Carbon Fiber Seat Heaters
    'Dropped' and extended passenger footbox
    Autometer 'Vintage Cobra' guages with reverse speedometer (includes Oil Temp guage)
    Low oil pressure warning light
    Battery Cut-Off switch
    Upgraded "bear claw" door latches
    NC painter - body work and paint
    Custom black paint with 'ghost' grey racing stripes
    hidden trunk hinges
    Team III wheels
    If interested, have questions, or want more pictures
    Contact: [email protected]
    FF Mk II IRS with 393 winidsor
    Daily driver - Monster Miata (331 ci Ford V8)
